- Nov 28, 2016
- 2,375
This afternoon I began machining a t-slot nut to mount an Aloris CXA tool post onto the compound...
...and discovered an issue with the compound.
I was using guage blocks to measure how thick to make the lower part of the t-nut... and found that the bottom of the upper lip on both sides of the t-slot is worn in the middle... there is a .015- .020 'arch' worn under the lip...
The only way I can see to fix this is to disassemble the compund and set the top slide up on the milling machine and use a keyseat cutter to skim about .020" off the bottom of the t-slot lips. I'm not sure I really want to do that because it will weaken the lips... but if the t-nut is only contacting the lips on the corners, it not only will be more likely to break the corners off, but also will not allow the toolpost to have a solid, rigid mount.
So... I think I'll give it a try... maybe next week.
-Bear
-Bear
