Sorry Outboardguy, been working 18 hr days. Finally got a day off.
Terry is correct about the wiring.
So if my brain is working right this morning, you will have 2 wires coming in to your drum switch (hot and neutral) connected as Terry said to termials 2 & 6 respectively on the drum switch.
You will also need to run a jumper wire between drum switch terminal #3 and drum switch terminal #5.
You will have 4 wires running from the drum switch to the motor that will connect to the spade bit type connection points on the motor as follows.
Connect wire from drum switch terminal #1 to motor connector #1.
Connect wire from drum switch terminal #2 to motor connector #2.
Connect wire from drum switch terminal #4 to motor connector #4.
Connect wire from drum switch terminal #5 to motor connector #5.
Motor connector should be male spade bit type connectors. From the picture they are as follows:
#1 - Top left of motor wiring picture. The male spade bit connector appears to have a black wire connected to it. This should be the wire for the starting winding shown on the drum switch wiring diagram (terminal #2 connection) and will have to be disconnected from the motor spade bit and connected it to the wire coming from drum switch terminal #2.
#2 - Should be the male spade bit connector top center of the motor wiring picture with Red and Blue wires connected to it (connect to unused spade bit in middle).
#4 - Top right of motor wiring picture.
#5 - Should be male spade bit connector bottom center of motor wiring picture with Black wire on it.
If this doesn't work, it's because the two black motor wires have been swapped (the ones connected at motor connections #1 and #5)
Like Tery said, if not running in direction drum switch shows, just swap wires #2 & #5 either at the drum switch or motor, shouldn't matter which.
