- Jan 31, 2016
- 11,448
Here's a few different style knurling holders . They all work . They also have their good and bad benefits depending on size and machine capability . This is really a subject as a parting tool where there is not a one tool does everything great . You're not going to knurl a 20" diameter roller with an Eagle Rock , and you won't be knurling a smaller soft shaft with a push type . For hobby work , the old time pivot tools would be my choice . You can be off center and it wouldn't matter . The Aloris shown is a good tool but has to be on center . The CNC knurler has adjustments foe each knurl and can also be rotated making diagonal knurls with straight wheels . TMI at this point . There is no cutting in knurling , rather deforming the surface . You NEED oil and plenty of it . You also need the correct wheels if called out on a print . You also need the correct diameter of the shaft when dealing with specs . Once again , all of the above depends on what you need for results .
