- Feb 8, 2014
- 11,144
Hi JD, so I'm assuming you recommend removing the chuck first and working directly on the spindle with the dead drop? If the chuck is junk, I can't measure off that anyway.
I have never done it with the chuck removed. The spindle is so short that you wouldn't be able to do much with a dead blow. You need the leverage of the length of the chuck body to be able to move things around.
If the chuck is junk then the only way to solve the problem is to remove the chuck and check the spindle taper.
