- Jan 5, 2014
- 944
So I have a broken street valve, 30 Years old, Watts Regulator Co. Can't find rebuild parts/discontinued valve. It is marked "W" 125, a 1" solder-in brass (or bronze) wedge-type gate valve. Local HW and plumbers don't seem to have compatible parts to sell (or don't care to bother looking).
The stem is broken just inside the housing, maybe 1/8" away from the packing. The stem thread is 0.30" diameter, stem is 0.335" diameter. I would rather avoid replumbing a new valve in a very tight/awkward space on copper pipe. I would need to move a water heater to have enough access (thank you contractors...). Right now, it is re-assembled without the gate in place so I have water, just no shut-off. I am on a well.
I suppose I have a few options:
Do nothing. Just shut off the pump if I have a problem. Have a beer or work on something fun.
Braze or silver solder the stem and machine off the excess solder/braze where it enters the packing.
Turn a new stem. 12 TPI Acme (counting both thread leads), 2 start, left hand, for about 1.5", smooth stem, drill/tap hole for handle. I have an Acme insert I used to turn a RH thread a while back. Maybe that is called 6 TPI?
I think the material is bronze, maybe brass.
What would you do? Braze or solder? Materials to use? I've never turned a left-hand acme thread. Tricks?
Thanks.
Thanks.
