- Nov 23, 2020
- 788
Looks like I am cutting a 1.5 thou taper over 6”. Let the fun begin
Try locking the compound slide and leaning lightly on the toolpost pushing the tool into the bar when taking a cut. This will take out some slack in the setup, if this cuts without a taper then it is slack in the lathe ways. If it still has a taper then you can disregard this. It is a quick test to eliminate one potential issue.Just did a facing cut .. almost no difference from to back (.0001-.0002 over 3") - so I am guessing that my gear head alignment is fine. Even though I used a precision level - doing the two collar test - I still have a .002 taper (the largest is towards the chuck). Im guessing that my ways are still slightly twisted.
What a pain in the ...
I had been looking at these but when I saw they were made in 1ndia I retreated. I have gotten some of the worst quality junk from there. But I did just order the MT5 test bar stated to have a max runout of 0.0002”. Thanks for the recommendation David.I invested in one of these - makes aligning the headstock very easy. Once the headstock is aligned you can adjust out any twist in the lathe bed.
Lathe Alignment Test Bar Shank Size 1MT, 2MT, 3MT, 4MT, 5MT, 6MT Hawk | eBay
2MT 283mm (11-1/8”) 0.0002”. 3MT 335mm (13-3/16”) 0.0002”. 4MT 386mm (15-1/4”) 0.0002”. 6MT 507mm (19-7/8") 0.0002". 1MT 151mm (5-15/16”) 0.0002”. 5MT 400mm (15-3/4") 0.0002”. Hawk Werkzeuge comprises of a dedicated and skilled team of engineers with an aim of providing you tools of highest...www.ebay.com
I have ordered one. I will inspect it and report my results here. Advertised TIR is 0.0002”.I've bought two of these both out of spec. In fact the last one I bought had .003" TIR. However, I was refunded the total amount I paid without needing to send back to India (2nd one).
I feel your pain. My lathe is cutting tapers too. And I thought I was going to spend my retirement making little steam engines.Just did a facing cut .. almost no difference from to back (.0001-.0002 over 3") - so I am guessing that my gear head alignment is fine. Even though I used a precision level - doing the two collar test - I still have a .002 taper (the largest is towards the chuck). Im guessing that my ways are still slightly twisted.
These photos and the descriptions that accompany each image might be helpful. I'll be interested to hear your measured run-out on the test bar. I spent $120 for mine hoping that would be an indication of quality, and was rewarded with a very accurate test bar - or perhaps I just got lucky.I had been looking at these but when I saw they were made in 1ndia I retreated. I have gotten some of the worst quality junk from there. But I did just order the MT5 test bar stated to have a max runout of 0.0002”. Thanks for the recommendation David.
