- Nov 23, 2020
- 788
Perfect timing for this thread. It's been quite a while since I checked level. I'd been planning to do it for a while and, boy, was it out of level. I got it level with the machinist level front to back and checked the headstock using the bar that David listed. It's been quite some time since I aligned the headstock. I had it perfect with the bar over the entire rod with an Interapid. I got it all tightened and verified alignment again. I faced a 3" aluminum cutoff and had a difference of .001" from center to edge. I did not expect that.
Did you continue to the other edge to see if you got back the .001 and are in fact machining a dish?
