- Dec 25, 2011
- 10,513
OK.
The nameplate says FLOOR but it's actually a BENCH model. The depth stop itself was made from a length of 1/2"-20 UNF all-thread. About 1/3 of it's diameter was machined away down to just into the hole on the tab sticking out to the right as you stand facing the DP It is screwed into the piece of 1/2" plate below the tab, which clamps around the quill. A scale a little longer than the stroke capability is attached to the flat with two drive screws. The head of the 1/4" clamp bolt is visible in the second photo just below the retract spring assembly. The quick-change stop visible at the top was bought separately.
