- Feb 2, 2014
- 1,069
This is a view of the gas tank parts before polishing.
And after polishing and installing on engine.
No gas leaks and I did not plan on trying to start the engine but curiosity got the best of me so I rigged up a temporarily throttle, opened the carb screw 2 full turns and gave it a try.
IT'S ALIVE
I was surprised as the only thing I have adjusted is I advanced the timing a little. The engine fires on both cylinders and I don't seem to have any major oil leaks.
There are several issues that need to be worked out like a proper throttle lever, the gas tank needs a extra support, the fan belt needs to be changed to a thicker one to dampen the vibrations from the odd firing order and then adjust valve, ignition timing and carb. These changes will take a few days to complete.
Thanks for looking
Ray
IT'S ALIVE
Thanks for looking
Ray
