- Feb 2, 2014
- 1,068
Yesterday because of the oil deluge I had I replaced all the gaskets and this time I used some silicone sealant on them as well.
No oil leaks found so far and I will keep my fingers crossed that none will show up later.
First I checked the valves for sealing and was happy to find them in great shape so I installed the cylinder heads on the engine. The lifters fit without any modifications but the push rods all needed to be shortened. I set the valve timing as close as possible for now and tightened the cams in place.
I also mounted a flywheel so I could turn the engine over by hand but this is not the one I will be using for this engine. I do have a larger one in mind.
Today I made up and installed the intake manifold and carburetor. I used copper pipe fittings with o-rings on two of the joints so I could remove the manifold later if need be.
I am trying to decide if I like the copper color or should I paint the manifold maybe black?
Do you have an opinion?
Thanks for looking
Ray
Thanks for looking
Ray
