- Nov 14, 2016
- 3,006
I don't have any experience with the 8x16 specifically, but I have developed an interest in the smaller size lathes. I have a Sherline 3.5x17", an Enco 9x20 and a Powermatic / Logan 11x24. Some will suggest you buy the biggest lathe you can fit / afford, but personally I believe in your logic of starting small since you really don't know where this will lead you.
You are asking about a specific lathe so I don't want to go too far down the path of alternates unless you want to go there except to say the 9x20 lathes have a pretty solid following, they don't cost a lot more than the 8x16s, but are about 100lbs heavier (250-ish vs 150-ish). There are several members here on the forum who have extensive experience with the Sieg 9x20.
Something I have found with the small Chinese lathes is you have to take their sizing with a grain of salt. Some liberties are taken with the measurements. Taking my 9x20 as an example, you can find it marketed by different brands as an 8.5x20, a 9x19 or a 9x20. In actuality these lathes have an 8.75" swing and the 19" or 20" depends on whether you are using a live or dead center. Some of the smaller 7x lathes have very optimistic between centers distances with the longer ones more accurate than the shorter (where every inch would be more critical).
It would appear you are looking at a Weiss WBL210 series lathe rather than the more common Sieg C4 and variants. I'm pretty sure HF is a Seig C4, and Grizzly maybe a Sieg SC4.
Weiss WBL210
Sieg C4
It appears Precision Matthews lathes are based on Weiss designs but they don't carry an 8x16 lathe, their smallest being the 10x22.
Dro-pros in Northern California sells Weiss lathes, and does offer the 8x16" WBL-210V. I don't know if there is a closer retailer to Washington, as the Weiss USA site won't come up for me. I think there are a couple of people on this site that have dealt with Dro-pros.
Dro Pros Weiss lathes
Weiss WBL210
Sieg C4
