I shimmed the upper bearing with some Dr Pepper can. Was able to wrap it all the way around one thickness as it was oversized quite alot. I used loctite to hold it all together letting it cure 24 hours. Hopefully I get some time from it. I'll sleeve it or make a new one at a later date.
It's really too bad you have to pull bearings to get top of the head apart.
I want to mount a DRO bracket to the spindle stop as others have done, but didn't want to do that work till I get it all checked out. It's such a thin piece, I'd like to maybe make a replacement that had a little more meat on it. Best time is before I get it together, but I think I'll visit it later.
I did tap some holes in the top cap to make it easier to pull off when the need arises.
Also, my spindle brake is broken in half. Was not installed when I got the mill. It's not available from Clausing any longer, but they do have most of the prints. I'll have to take it all apart after a replacement is made. Will have to order some cast iron for it.
Hope to cut a few chips tonite and then plan for next steps.
DRO
Spindle Brake
DRO Spindle Mount
All the help and advice has been great. Keep up the good work
