New to me 8520. Just got the knee gears replaced. All there is as it should be. A cover for them would be nice.
Was moving onto the head and noticed the spindle step pulley had some wobble in it. Got it off and noticed that the bottom bearing does not press on at all. I can drop the pulley over it by hand and gravity will pull it down. Looking at the ID I can see the aluminum is displaced or worn in. Maybe burnished?
There is an old thread about possible corrections. One of the options was to buy the next size up in OD and just turn the ID of the pully a bit larger. Since I need new bearings, this avoids a sleeve, pressing and more precise parts that need to fit together. I thought I may also be able to get wider bearings and not need the snap rings that separate them.
Provided I can find bearings to the right dimensions? how does this solution sound?
Also, my idler pulley has a lot of wear in one of the grooves and is probably worn out from too much belt slippage. I've read on other threads they are not available. How much luck have others had in sourcing other pulleys and machining to fit? I've seen these recommendations, but not the discussion of how it worked.
I also thought about trying to get a wider gage belt, but the smaller pulley diameters may not allow a wider belt around such a small OD pulley.
