    Dismiss Notice
600V 3-phase motor (milling machine) --> 240V operation
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by slow-poke, Apr 20, 2017 at 10:16 AM.
  1. slow-poke
    slow-poke Canada Iron Registered Member
    6
    3
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    I have been on the lookout for a bench top mill for occasional use (should be a good compliment to my Emco 8 lathe). I found a local one for a reasonable price ($500) however it is powered by a 3 phase 600V motor. So I would either need a converter or replace the motor to single phase 240V.
    Has anyone done this?
    Converter or swap the motor?
    Estimate $ for the conversion?
  2. markba633csi
    markba633csi United States Active Member Active Member
    192
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    You could shop around for 600 volt variable frequency drives and compare the price vs a single phase motor- The VFD would give you some speed control but at what cost?
    Mark S.
  3. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    320
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    Unless it is some weird frame size motor I would suspect finding a replacement single phase motor would be the least expensive option.
    I don't know of any 240V single phase input VFD's that output 600V 3 phase.
    You could build a rotary phase converter to convert from 240V single phase to 240V 3 phase and then add a 3 phase step up transformer to get it up to 600V. I don't think that would be very cost effective for just one machine.
    Chipper5783 likes this.
  4. hman
    hman Active User H-M Supporter-Premium
    753
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    A benchtop mill with that huge a motor??? Sounds like the seller or a previous owner went way overboard on power! And I can almost envision a huge motor scabbed onto a small mill and overbalancing it to the rear :)
    I'd agree with changing out the motor for a single phase 240V (1 ½ to 2 HP) as the most economical solution. Round column mills (which I'll suppose your candidate is) come from the factory with such motors. Often they're wired for 120/240, but the current draw at 120V is pretty high. So 240 is the way to go. You'd have to rewire the switch, of course.
  5. CluelessNewB
    320
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    Just because it is 600V doesn't mean it is all that powerful. It might be only 1hp.
  6. slow-poke
    6
    3
    City:
    Toronto
    State:
    Ontario
    -Return to Top-
    I spoke with the seller, he will send me a picture of the motor plate, he said he does recall it being 1.5HP Mill.JPG
  7. tq60
    tq60 United States Active Member Active Member
    129
    43
    City:
    madera
    State:
    California
    -Return to Top-
    Do not waste time here.
    The 600 volts may be wrong data as this looks like typical hf or other low end mill.
    Get photo of actual motor to confirm as it is likely single phase native voltage of where first sold.
    If it is some odd 3 phase voltage the cost to convert to single phase house voltage more than mill is worth.
    If price is real cheap the motor can be replaced as they just mount to plate at real like normal drill press which these mills are almost...
  8. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    1,529
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    In the Canadian area that he's in, it is very likely the motor is set up running off of 575 volts, not 600 volts. That is a common voltage for that area. I have a surface grinder that had a 575 volt motor on it that can from that area. Guess what, it got pulled and chunked into the junk pile, and a 230 volt 3 phase motor put in its place. I operate it off of a VFD on 230 volt 1-phase now. Ken
  9. Chipper5783
    Chipper5783 Active User H-M Supporter-Premium
    312
    63
    City:
    Red Deer
    State:
    Alberta
    -Return to Top-
    Sure. Not really a big deal (been there done that). I assume that you have 3 phase power (RPC, or what ever). When faced with the same issue, I got a 240-600V 3 phase transformer (found a good used one), plugged it into my 3 phase (RPC) distribution and it works great. I now have 3 machines on this (having 600v - 3 phase has opened up some nice opportunities).
    I was fortunate to get the transformer for $100. However, powering things up was just so easy (no issues with motor mounts, shaft size, controls) - the changes are external to the machine. Of course it is possible to change motors - depending on all sorts of factors whether it is easy or hard. All I am presenting is that plugging in a transformer is easy.
    If I were to do it again and I had to pay $1000 for the transformer - I would still go with the transformer option (quick, easy, works great - sometimes those considerations are worth paying for).
    Let us know how you make out. Regards, David
    4gsr likes this.
  10. Keith Foor
    Keith Foor Active Member Active Member
    175
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    Be advised about running equipment above 440 volts.
    For some reason the 400 volt threshold is a level not to be crossed by the faint of heart.
    240 volts if it shorts will typically just make a bang, melt some wires and blow a breaker.
    The higher voltage stuff will create sustainable arc's and plasma balls that will burn for a longer period of time and tend to really roach things before it gets done cooking.
    I am not trying to indicate that it's not safe. It's used every day in industry and works well. But it has to be respected more than the low voltage stuff for the reason mentioned above.
    Be safe and have fun
    hman likes this.
Share This Page
