6.5mm Creedmoor Bartlein Barrel and Impact Action
2,700 rounds in a high power rifle is a lot of use, IMHO.
.001" per hundred rounds movement.
I don't know very much about the subject, but it seems like .027" is a bunch.
That's my first 6.5 CM and I have read that the barrel is good for about 3000 rounds. Now Dabber's awsome 6.5x47 Lapua should get longer barrel life (or so they say). He needs to get out and shoot it more!
Yeah, I should. The stock is an Accuracy International foldable stock, so it is really heavy.
The comp is titanium, with 7.5 degree forward vents for maximum flow. the 6 vents are every 60 degrees for a balanced design. .010 clearance between bullet and vents. As such, there is no perceptible recoil - you see the bullet hit the paper every time...
I quit my range membership 2 years after building this... so I haven't had it out much.
"" there is no perceptible recoil""
That's incredible. I had a Cooley compensator on my Colt receiver, on a high end match barrel and bolt (JP Enterprises) in my AR.
I was amazed how much recoil was reduced.
Example. With a standard AR shooting 5.56 vs my Colt AR I would lose my site picture from re-coil, the compensated rifle stayed on the bag, I never lost my site picture.
I'm sold on them, they work.
Nice. I haven't heard of the Cooley. The comp is my design - influenced by some of the swiss High pressure flow models on their sound modulator designs... note this compensator is Very Loud Indeed... (standing behind the shooter still requires serious hearing protection)
Yes, I had forgotten about that.
At my range there are concrete walls separating the stalls.
I had to wear quality ear muffs along with the foam inserts.
Do you have drawings that you could share for this compensator?
In the AR world a Benny Cooley compensator was a big deal.
I don't know much about it.
Dabbler,
You made one??
That's not an easy thing to do as I understand.
re: drawings: I made the drawings around 8 years ago. I could reproduce them, I guess.
The trouble is, that everything has to be turned concentric, and that the barrel threads have to be concentric to the lands to about .0004 or you will get serious problems. (the closer the better - we managed to get withing .0002 on concentricity and over .500 we were within one and a half tenths straight to the exit vector of the barrel. There are a bunch of operations that happen from one side, then it is turned around and indicated in to one tenth in order to get the other ops to be right. The external threads on the comp are less picky... I suppose you could relax things a little and make the bore .040 larger than the bullet. We chose .010 for our design.
The slots are made with a .125 HSS cutter, and they are (from memory) .210 wide. these are cut using a rotary table that is super solid, holding the finished piece at a 7.5 degree downward angle. Trouble is, it is very touchy, and until I made several, it was easy to break the cutter off. Titanium is very sticky. Most carbides won't work because you need a very positive rake tool to cut with low enough pressure not to pooch the cutter. It takes a looooong time to cut those slots... I think it took about 40 minutes each, and there are 30 of them to cut... I did about a third of them and a friend of mine took over, and then I finished off the last few.
The optimum for a comp seems to be around 40% of the force from the blast, since there's nothing that can be done about the reaction force from accelerating the bullet. On our recoil sled, we seem to have achieved about 38%, by our calcs. the rest of the perceived recoil is taken up in moving the rifle - with the big scope it weighs 10 Kg (22lbs).
Finally got this rifle finished!
Threaded the muzzle 5/8"-24
and made a brake with a design I have been wanting to try
I went all in on a stock from Foundation (these are incredible)
Using a load specific to my Howa 6.5 CM it shot okay (I need to work up a load specific to this rifle)
Well done sir.
Did the break work ok?
I've never seen that design. Patent? :)
