- Jun 12, 2014
- 4,826
I am not sure I would expect that level of accuracy from that particular chuck, but still should be within the +/-0.002" range would be reasonable. Most chucks are much worse. You might also check it with a 3/8" end mill. It is difficult to get below 0.001" no matter how good they are they will vary a bit depending on what they are clamping. Since they are integrated chucks there is not taper interface that could be off.
If you want a bit better precesion then you might look at their ultra high precision which is just slightly more. I have used this 5/8" chuck on another persons mill and it was very smooth and worked well.
