32x40 H -- Gas Engine
I think tomorrow will bee the big day for a test without rings, just to see if a piston lapped to the bore works, just for fun,
Video camera has arrived so we are all set????
Keep fingers crossed. Brian.
At last I have a running engine. it seems a long way from the first doodles a year ago to hearing it run today.
the carb is a little erratic. but otherwise all is well, I have made a short video, all I have to do now is find out how to up load it.
Talk about old dogs and new tricks I struggle with the changes but we get there eventually.
Brian.
Very nice work Brian. Can't wait to hear it run.
Darrell
Thanks Bill, the mixture needs attention and the best timing found . but it seems to run just fine.
Brian .
Have worked all day tidying the drawings and making the notes for the plans book.
Thank you to Nels for the info on down loading video it works a treat.
Brian.
Today was taken up fitting the piston rings, now I have to make a cover for the crank case and paint the raw cast iron barrel and head.P1013073 (3).JPG
Lots more work to do.
Brian.
