- Apr 30, 2015
- 11,309
Higher ohm readings than I predicted but all very similar, looks Aok to me- Randy I think your problem is something else
Mark
Mark
Can you come up with a safe way to connect the motor (fully assembled) to your source 3-phase to eliminate any other circuitry/components? If it runs OK connected directly, then you know the motor and source are OK and the trouble is someplace else. If it doesn't run OK, it's either the motor or the source...
Good luck,
Ted
