    Dismiss Notice
3 Phase Motor Troubleshooting?
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by randyjaco, Jul 17, 2017.
  1. markba633csi
    markba633csi United States Active Member Active Member
    361
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Higher ohm readings than I predicted but all very similar, looks Aok to me- Randy I think your problem is something else
    Mark
  2. RandyWilson
    RandyWilson United States H-M Supporter - Premium Content H-M Supporter-Premium
    164
    43
    City:
    Chesapeake
    State:
    Virginia
    -Return to Top-
    Could the higher resistances be because it is wired for 480V?
  3. Technical Ted
    Technical Ted United States Active Member Active Member
    125
    33
    City:
    Dansville
    State:
    New York
    -Return to Top-
    Can you come up with a safe way to connect the motor (fully assembled) to your source 3-phase to eliminate any other circuitry/components? If it runs OK connected directly, then you know the motor and source are OK and the trouble is someplace else. If it doesn't run OK, it's either the motor or the source...
    Good luck,
    Ted
  4. randyjaco
    randyjaco Reserved Active User H-M Supporter-Premium
    187
    63
    City:
    Friendswood
    State:
    Texas
    -Return to Top-
    Well I got it running. I pulled the motor and cleaned everything up. There was some black crud on the rotor (like burnt grease). I put it all back together and hooked it up directly. It now runs. The downside is that it seems to have minimal start up torque. The bearings are good and everything turns super easily, almost no friction. But when I turn the motor on, I get a buzzing sound for about a second, then it spins like a turbine. I plan to use a VFD on it. Any recommendations for settings to make it start up faster and minimize the buzz?
    Thanks
    Randy
  5. Technical Ted
    125
    33
    City:
    Dansville
    State:
    New York
    -Return to Top-
    If you look at your VFD manual are there any setting you can tweak to help? Or, can you test it some how on a true 3-phase power source to see how it performs then? 3-phase motors are fairly simple devices, so you might want to verify your source of power isn't causing what you are seeing.
    Ted
  6. markba633csi
    361
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Randy may be correct- it may have been rewound for a higher voltage, hence the low torque on your lower voltage supply. That might be the reason for the epoxy coating too.
    What I would do is collect some winding resistance information for 440/600 volt motors vs. 220 and see if that explains the 6.5 ohm readings you got. Also put a clamp-on ammeter on each leg and see if it jives with the nameplate amps.
    Mark S.
  7. Technical Ted
    125
    33
    City:
    Dansville
    State:
    New York
    -Return to Top-
    Can you contact the person you got the machine from and see what voltage it was run on when they owned it? And how they ran it, whether a VFD or true 3-phase?
    Ted
  8. randyjaco
    187
    63
    City:
    Friendswood
    State:
    Texas
    -Return to Top-
    The motor plate said 220. The previous owner never got it running and God only knows where he got it from. Just judging from what I saw tearing it down, I believe I am the first person since the factory to see the inside of that motor, but anything could have happened.
    Thanks
    Randy
  9. Technical Ted
    125
    33
    City:
    Dansville
    State:
    New York
    -Return to Top-
    Well, you would like to think that if someone was to professionally re-wind a motor for a different voltage that they would re-mark/re-stamp the motor data plate.
    Ted
  10. randyjaco
    187
    63
    City:
    Friendswood
    State:
    Texas
    -Return to Top-
    I would agree. I also know from taking a similar motor to a motor shop, that having a motor rewound is an expensive proposition. They wanted nearly a Grand to do mine.
    Randy
  11. RandyWilson
    164
    43
    City:
    Chesapeake
    State:
    Virginia
    -Return to Top-
    I have a mill with a very clean looking three phase rewire that retained all of the original two phase plates.
  12. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,213
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Put the motor back together and take it to your local favorite motor shop and have them check what voltage it runs on. Lets hope it is 230 volts. If it runs on 460 volts, you will know for sure it is. They shouldn't charge just for doing that I wouldn't think.
  13. markba633csi
    361
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Only hitch is that he'll have to bring the whole machine to them, the motor is part of the frame.
    Maybe the motor shop could just tell you based on the ohm readings what voltage it is expecting...
    Mark
    4gsr likes this.
  14. randyjaco
    187
    63
    City:
    Friendswood
    State:
    Texas
    -Return to Top-
    Mark is right. I would have to take a @500 pound 1hp to the shop. The jointer is direct drive. The motor and the cutter head are all the same assembly. Hence my concern for the motor. I can’t just toss the old motor and replace it with another. If I could I would have instantly replaced it with a single phase motor and ya'll never would have known that I had a problem ;-)
    Randy
    4gsr likes this.
Share This Page
