- Nov 23, 2017
- 1,191
If they are sealed bearings, factory packed with grease, you will probably have problems. Open bearings would be best, with a few drops of oil added to the air inlet every time you use it, and add a few more drops every 15 minutes or so if you are using it for longer than that. High speed bearings need cool air brought to the bearings to keep them cool. Grease causes too much friction at high speeds, and adds resistance to free bearing movement, friction that becomes heat. Make sure you use clean air for your air tools. The interior of the tool needs to be kept clean. Install an inline filter near the shop air outlet or the tool inlet to keep junk out of the bearings and the vanes of the motor.I tried Quality ball bearings made by skf and that doesn't work
i have a turbo-charger disassembled on the bench as i write this.
turbochargers are known to have significant speeds incurred during operation, often bordering on hundreds of thousands of rpms.
in the turbo i have apart, there are bronze bushings that have radial orifices drilled for circulation of engine oil.
the tolerances are fine, less than .001" clearance anywhere.
i'm sure 954 aluminum bronze would stand up to the service
i'd recommend lapping the bushings to dimensions and using turbine oil
or possibly using graphite impregnated bronze bushings
That's a great idea, it will work fine, if you have an oil pump to supply the hydrodynamic bearings you are describing and a sump for the oil to drain into
