- Mar 20, 2014
- 440
The HF LED light may not work on all helmets, it needs a location that is kind of flat and matches the angle of the light. On mine I added a nut and a flat washer between the bracket and helmet to elevate the rear of the mount to get it pointing where I needed it.
So are you saying that the light helps WHILE YOU ARE WELDING or just helps you see where to strike the arc? As I get older, I find it harder to see the weld puddle, even with my auto darkening helmet on 9 (the lowest setting). If you are saying this helps to see the weld puddle, then I'm off to Harbor Freight TIA, JR49
