I had a 1936 74 Cu in flathead Hog for a while, then the wife and children came along and safety ruled.
I have a new project associated with the rubber band airplanes, assembling the components into a winder (production, I gotta make five to start). The winder consists of a wooden handle, attached to two aluminum side plates which enclose a couple of gears, driven by an external handle and turning an external hook (for the rubber band). That's enough explanation. After drilling the [three different size holes, six of them in about 20 side plates] the next step is to insert the 7/16 OD bushing and the 5/16 OD bushing. the latter wouldn't go. The mikes came out and found out why, the hole was [sure enough] .3125, but the bushings, all 30 of them were .315, sintered oilite. Here's the problem.
As you can see, it won't go in the hole. I thought about reaming the hole, but I don't have an expansion 5/16 reamer, so the next best thing is to re-turn the bushing. Right. that flange won't take clamping on, hmm. how about an arbor. I found a piece of mystery steel rod, well more wire, it wasn't at all straight. about .145 OD. I cut a inch and a half of it and put it in the 1/8 collet in my Ames turret lathe. Turned it down to .125 (the ID of the bushing, ran a 5/40 die on it and found a washer with a 1/8 ID. Here's the arbor.
I had to make the nut, a piece of 1/8 flat 1018, drilled and tapped, and hack sawed out. I really hate working tiny things, and I was trained as a toolmaker, we only make one off. If we make two, it's because the first one was wrong. And I've got 30 of the bushings to reduce.
Here's the arbor in the collet.
And here's the process, before and after being turned. I had problems holding size, starting at .315, I could get .313 with no trouble, but it wouldn't go down to .3125. Not without going under. I guess I can push that .0005 into the side plates.
If it weren't for bad luck.......
