- Jun 12, 2014
- 4,822
Have had my horizontal bandsaw for a few years, and always had problems cutting short pieces of stock near the blade. It was exacerbated when trying to cut an angle in stock. There is also the problem when you clamped short stock the clamping vise plate would twist so the piece was not held by parallel vise plates. Finally got around to fixing the issue, I milled four 1/4" deep slots in some 1/2" aluminum plate to allow lateral adjustment of the plates. I use four button head 3/8-24 screws with thin SS washers to hold the aluminum plates to each vice surface. This give me an additional 2" to move the plates toward the blade when doing angle work. I also tapped four 3/8-16 holes in the plates for an adjustment stop that I machined from a 5" SS carriage bolt. The stop is set to the same thickness as the stock that I am cutting, and prevents the vise plates from twisting when clamping small stock. The plates are symmetrical so they can be flipped or used on the opposite face. Works very nicely, and is easily removed if needed.
