- Aug 22, 2012
- 4,293
Made an angled cutter boring bar. I already had the bar with a bit at 90 degrees but it left too large a section of unbored hole so I added this bit to the other end.
The bit is not optimally ground but seems to work, old broken centre bit re-purposed.
so I could bore to a flat ended hole.
Not perfectly flat at the end but good enough for me.
35mm dia hole, to be threaded 39x4mm with a 10mm wide registration at the front.
I will grind a new bit to make the thread run out at the bottom of the hole.
