- Aug 22, 2012
- 4,292
savarin, I think you'll find that if you open the knurler up a bit more and crank it in so that the wheels are right at the top and bottom of the work piece, you'll have a bit more power to press in the knurls and it may not move around quite as much. You probably won't need to use a wrench on the jack screw. It's about 5 to one power advantage, at least on mine.
I recently knurled an 8" long wrench handle without having to support the end with the tailstock. Only possible if the wheels are centred on the work.
Hi Hawkeye,
thanks for the design its a cracker.
That was how I ran it when I used it but that was just eyeballed not measured, I think I have a problem with concentricity (is that a word?) somewhere as when knurling it tightens and loosens as if the part is egg shaped which it isnt.
The photo above is after the event when I pulled out and moved everything for the shot.
I also used a handle to turn the lathe instead of power.
I believe that as the axa tool post is still using the original 8mm tool post bolt instead of the supplied 14mm bolt there is a lack of hold down force and the strain of knurling at the amount of off set pulls (if the wheels are just over vertical) or pushes the tool post (if the wheels are just before vertical) around although this has never happened before with conventional turning.
I obviously need a heap more practice so thats todays job.
