Was lazy and asked the local Deere Dealer what it would cost to change out the clutch on the tractor. It’s nothing fancy , open cab hundred horse tractor. Was quoted 2000. Sounded reasonable so I went ahead and said ok. This was in September last year. Just now received the bill of 13000. How did it take three months to change out the clutch and just now to come out with a bill. The clutch is a wet clutch so the transmission has to come out. I changed out a power shift transmission in a 6300 a couple of years ago and it took me about 20 hours. I figured the the should be about the same or less. Looking at the bill there is a steering valve that was replaced for being cracked , a new steel hydraulic line and a main throttle sending unit changed out that were fine when the tractor went in. My best guess is something happened when they were splitting the tractor and didn’t have everything thing disconnected they should have. When the tractor came back the pot that worked before now didn’t and there were over twenty nut and bolt visibly missing. This is what happens when I let someone work on my equipment. After talking to the service manager they took off 1900 from the bill. Even so that is an unbelievable cost for a clutch replacement. The tractor after repair is only worth 20 thousand. Never underestimate the value of being able to do your own repairs or being able to machine your own parts. Sorry about the rant. I am still in shock.
