- Mar 25, 2013
- 4,624
Thanks guys. I'm glad someone is following this!
I may put a flat piece of sheet metal in the bottom like a tray to catch dust and particles and make it easy to clean. My bandsaw has something like that. I designed the table mount to make it easy to get back to 0 °. You just drop the table until it hits the horizontal mount on the left; that acts as a zero stop. I plan to make the table in an L shape and have the table extend past the belt (posterior to) on the left. Will that be sufficient or should I make the table in a U and have it extended on both sides? That will be harder to cut.
I have been seeing online that people are using ceramic and glass platten faces. Any good reason to go to that? Does anyone use such a thing? I also saw a water cooled platten! If my platten gets warm I plan to add the heat sink.
Just waiting for some parts and I can have a video of it in action. I have about 30 lbs of belt tension. The vertical arm is fairly rigid. The tracking works very well. Overall, this thing feels fairly heavy duty and should work well.
Robert
Robert
