2" spindle questions
astjp2
Aug 23, 2013
970
OK, I am looking for a face plate for my lathe. My lathe has a 2-1/4" x 8 tpi spindle. I found a face plate that says it is 2" by 8 tpi? Is there such a spindle with that spread or are the sellers on ebay just measuring the hole and are not compensating for the threads? Any Ideas? Thanks, Tim
this is the one I am looking at:
This one says sheldon , south bend and causing. It's a dog drive
I put that one on my list, I also need one that I can bolt a flange to and bore. Thanks, Tim
Sorry Tim, I only found that one. If you go to similar items at the bottom there were a couple face plates in the 2 1/4" size, smaller than the 11" model you showed, maybe they will work for you
