- Apr 30, 2015
- 11,329
Someone has been messing around in there haven't they? Has the stop button been bypassed? I see (I think) three wires on #22 and none on #14
-M
-M
Part of it was me lol. That picture of the stop button is deceiving, only red and yellow are actually on #22.Someone has been messing around in there haven't they? Has the stop button been bypassed? I see (I think) three wires on #22 and none on #14
-M
Thanks. Its definitely quite the event when the contactors latch. They flutter a little, not sure if a transformer would clean that up. A VFD would be a dream...maybe some day. One of these days I'll pickup a current clamp....or an oscilloscope. I'm curious how high the in-rush current actually is.Hey! Cool news! You'll have fun with that
I won't forget.Probably the high current surge from the motor is tweaking the AC waveform into a pretzel momentarily. As long as it eventually latches.
That will most likely vanish when you convert to 240 V since the current will be halved
Remember when you do convert you need to connect one of the (formerly flying) yellow leads to neutral instead of power so that the control box is still powered by 120 volts.
-M
yeah...I plan to inspect/remove the reversing circuit. At least I could clean up some light aluminum stock if I needed to.So the latching function isn't actually working it sounds like? Yeah you have more troubleshooting to do. You really want the e-stop to function as it should
