- Apr 30, 2015
- 11,329
You may be able to run it on a 30 amp circuit but you need to be careful- the wiring in the walls may heat up and you don't want to burn your building down. Remember the startup surge can be as high as 5X the running current so you need a breaker with some time delay, 2-3 seconds.
You really should consider running 240 volts sooner rather than later for a motor that large; it's easier on the contactors, less arcing, for one thing. More power delivered to the motor with less voltage drop in the supply wiring for another.
In theory you could run the contactors straight off 120 volts but I wouldn't. It's not as safe and they will overheat and fail prematurely. You really should get a 120 volt isolation transformer that has a 100 volt tap. A 100 watt unit would be sufficient (100 VA) You can use the same transformer when you switch to 240 volt service, you just run a neutral so you'll still have 120 volts to supply the transformer.
Believe it or not this would probably work: I don't know if it's isolated or not
Koden StepDown Transformer AC 100 volt | eBay
Input: AC 120V Output: AC 100V. For 100v appliances from Japan. Good Working Condition. The machine I used it for no longer works so I don't need it anymore.
www.ebay.com
