if you use a turbine quality R&O 68 oil,you will be ok,except possibly where there are freezing temperatures,where a 32 may be better.......the R&O stands for "rust and oxidation"(of the oil),and is generally a water shedding oil.....so condensation should end up in the bottom of the head,not circulated into roller bearings.....Dont use motor oil....it emulsifies dirt and water,and has very little actual lubricating value.
