The pin will keep from moving out there a friction ring on the lever that hold in place when you moving the lever
This same way the 10K has it.
Dave
Ah..... Mark- here's the answer to your question. This guy used a split ring on the back side of the plate:
http://www.practicalmachinist.com/v...ng-renovation-270736-post2112453/#post2112453
EDIT- here's another option where a grove was machined into the tumbler shaft, and a dogpoint setscrew as used in the head casting.
http://www.practicalmachinist.com/v...installed-9-abc-129098/index2.html#post589472
