Somewhere along the line, I ended up with a Carrera 10"x 100 tooth non ferrous metal cutting blade that I use in my
radial arm saw. Possibly even eBay? I've cut aluminum and several different brasses/bronzes with it. Just finished cutting off a couple of pieces
of 8 x 3/4' aluminum bar. Works great! Just have to remember to cut from the front of the saw to the back, i.e away from you instead of pulling it towards you in order to keep the blade from catching and forcing the saw towards the operator. I took 4 passes through the plate to 4 different cut depths. Actually much faster and much cleaner cut than on a band saw!, at least any bandsaw that I could afford. The cut looks almost like it was milled. Very flat and smooth with very minimal scratches on the newly cut surfaces. As usual, with a carbide tipped blade, wear proper protection and keep the bade guard as close to the metal surface as possible to avoid any possibility of flying carbide pieces, never happened yet for me. Face guard as well as eye protection and a very necessary use of hearing protection! The blade works great on plywood even though the tip angle is wrong I've cut baltic birch plywood for cabinets and the cut is as good as I've ever gotten with other plywood only blades. I've had the blade for several years, long before I got my lathe and minimill. I've even been able to cut very accurate slots in both brass and aluminum pieces that now I would use my little mill for.
Chuck the grumpy old guy
