- Mar 10, 2015
- 309
Hey Guys Want to toss around Table saw blades see what you all are using
I have a delta table saw right now that is well lets say not so rigid However its mounted in a Rasau table which has an awesome fencing system. Btw My wife found an old craftsmen table and brought it home.. NOW kick myself in butt got rid of it on a move never put it together modified fix it. . Anyway a few years back had to make a magic disappearing box for my daughter talent contest so i went out and bought an inexpensive table saw .
I have a 10inch delta ... what id like to cut mostly is 6062 T6 alum stock 1/4 to 1" . The blade im using works ok i think its 60T not sure what brand. . It does well but id like to see if i change i perhaps It can do better . Most of all How much is worth investing in/ Considering the saw is going to run out some regardless the the quality of the blade. ..
Regarding Blades choices they are 60T 80T or 90T. I have a Diablo 80T at on a saw at work that works pretty good However the saw has a nice motor and arbor to drive it .
What would you prefer what are you all using and is it worth it to spend on better blade for my saw?
Diablo
Dwalt (says USA
Irwin ( says made in Italy)
Diablo
Dwalt (says USA
