Beautiful work. Just a dumb question, are the pistons in your engine 2 way with a slide valve?made the control arms and started test fitting parts
That is some seriously impressive tiny work @tghsmithturned, cut, soldered and threaded a little brass, these are the the mast rings and covers, the one on the forward deck is also working as the deck hold-down fitting..
