    Dismiss Notice
1-2-3 Block Recommendations?
Discussion in 'GENERAL DISCUSSIONS' started by Uglydog, Feb 2, 2017.
  1. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I've been using some unhardened 123 blocks I made from cold rolled on my mill.
    They've worked well enough for most set ups. However, I been wishing for something far more accurate for inspection.
    Yes, fabbing some from this chunk of 1" O1 tool steel is option, but in the absence of a grinder I don't think I will be pleased with my results.
    I'm good with used precision shop made and import. Ebay can be problematic for precision instruments/tooling.
    Does anyone have recommendations for a reliable source for precision 123 blocks?
    Or, have someone have extra good used ones they want to sell?
    Note: I don't have a jig bore? Thus, I don't need silly accurate/precise.
    Daryl
    MN
  2. royesses
    royesses United States H-M Supporter - Premium Content H-M Supporter-Premium
    355
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
  3. tomh
    tomh Active Member Active Member
    150
    43
    City:
    oxford
    State:
    Alabama
    -Return to Top-
    Try to find a set that the bolts will fit through the unthreaded holes. There are a lot of sets out there on ebay and through some importers that the bolts don't fit. I have a set that I got from enco and not being able to use the included bolts they have very limited uses.
    If you can talk with the seller to make sure that they do otherwise you are wasting your money.
    Uglydog and Reeltor like this.
  4. Billh50
    Billh50 Active User H-M Supporter-Premium
    946
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    you will find sets with through holes, some through and some tapped, as well as solid ones. I like the ones with both threaded and through holes. These can be bolted to angle blocks or flat plates for various setups. Most all of them are accurate as for size.
    here is a set with both through and tapped holes.
    http://usaknifemaker.com/123-block-set.html
    Guv, Profkanz, Uglydog and 2 others like this.
  5. chips&more
    chips&more United States Active User Active Member
    1,127
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    I have collected several 1,2,3 block sets through the years. And can probably count on one hand the times I have used just one set. And I’m sure it was not for the reference of any of its size measurements. Can’t explain why someone needs them and why I do not? I am in my toy house just about every day too. However on a similar note. I do have and use daily, parallels of various sizes. I have many sets of them and use them. I have working sets that I don’t mind seeing a scratch or two on them. And then I have like new sets that I baby. I even have the spring wavy ones that come in handy…Dave
  6. rgray
    rgray Active User H-M Supporter-Premium
    282
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    The cheap ones are plenty accurate. They are $12.00 a set from CDOC. They won't bolt together but I've never needed that as I have angle plates.
    I'd be happy with 123's with no holes but they are more money, seems backwards.
    I'm usually using them as spacers on the surface grinder, and I keep one with the lathe and use it to square the tool post off the lathe spindle, and even off the chuck face at times...they are way more accurate than needed for that.
    Uglydog likes this.
  7. sanddan
    sanddan Active User H-M Supporter-Premium
    606
    93
    City:
    Damascus
    State:
    Oregon
    -Return to Top-
    I have 2 sets of 123 blocks and use them often. I'd love a set of 246 blocks also.
    Ulma Doctor and Uglydog like this.
  8. Uglydog
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    tomh,
    Thank you for the reminder! This is exactly what I was hoping for was some input before I drop some $ on stuff I cannot use.
    Daryl
    MN
  9. Uglydog
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    Interesting short video from Suburban Tool. ..
    Daryl
    MN
    WesPete66 and Groundhog like this.
  10. 12bolts
    12bolts Global Moderator Staff Member Active Member
    338
    83
    City:
    Hinchinbrook
    -Return to Top-
    From the website "The blocks have 23 holes through them. Five are threaded 3/8-16 NC, and the other through holes are 5/16" diameter." What is the point of that? It just makes them as useful as a solid block!
    edit Although I guess they are lighter........
    Cheers Phil
  11. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    535
    113
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    Does drilling them out relieve stress before grinding, or something?
  12. royesses
    355
    63
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    I have not come up with a reason for 3/8 threaded holes with 5/16" through holes or a reasonable excuse for making them that way. Seems that all the Asian blocks are that way. I did watch that Bailey video last year hoping to find out why, but no such luck. I use them as spacers, cheaper than solid blocks.
    Roy
    Ulma Doctor likes this.
  13. Billh50
    946
    113
    City:
    New Britain
    State:
    Connecticut
    -Return to Top-
    not sure why they have 5/16 thru holes instead of 3/8. probably because they can use the same drill for both thru and threaded holes. But the threaded holes are handy at times to bolt an angle block from behind with a 3/8 screw so no screw head is in the way. The thru holes can be used to bolt it to a plate when the screw head would not be in the way.
    Ulma Doctor and royesses like this.
  14. Uglydog
    1,028
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    On my shop made 123s I've found that my counter bored through holes handy to bolt the block to the table.
    Because I have tapped right angle blocks I've scraped in I haven't bolted the 123s together.
    However, I've found the tapped holes in the 123s handy for bolting small parts to the blocks.
    Seems like I've been doing more mill work that doesn't hold in a vise.
    The 123 also work well on my RT as well as the mill table.
    Daryl
    MN
    Ulma Doctor, royesses and rgray like this.
  15. EmilioG
    EmilioG United States Active User H-M Supporter-Premium
    294
    63
    City:
    HUNTINGTON
    State:
    New York
    -Return to Top-
    Suburban Tool has a value line of import blocks and other tools. Must be well made if ST are putting their name on them? The ST value line 123 blocks do not bolt together though. $25.00
    The USA ST 123 block set is $111.00 plus shipping. These are nice. Moore Tool 123 blocks are awesome also. Where do they sell new Moore Tools 1 2 3 blocks?
  16. Profkanz
    Profkanz United States H-M Supporter - Premium Content H-M Supporter-Premium
    10
    3
    City:
    Santa Ana
    State:
    California
    -Return to Top-
    I like the Moore set a lot. No protruding bolt heads. Sometimes a small bolted up angle plate is just what is needed.
  17. Profkanz
    10
    3
    City:
    Santa Ana
    State:
    California
    -Return to Top-
    I'm sure the ones where the bolts don't go through are made on CNC mill and all holes drilled with a 5/16 drill. Some holes are then tapped 3/8-16.
    Some programmer in China who had no as to what these were for should have used 3rd tool for the clearance holes.
  18. petertha
    petertha Canada H-M Supporter - Premium Content H-M Supporter-Premium
    163
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
    I'm no expert but my gut tells me someone from Knockoff 123 BlockCo figured it was less expensive to drill all pilot hole size & tap every odd one. A) without fully understanding how they were intended to be used or B) maybe just pulling the winky-winky on people (like me!) who didn't know better. I fully admit buying these & figuring I must not be using them properly. The Suburban video was valuable in highlighting this point - completely useless if the intent is to stack & bolt them together. Yes they knockoffs, yes are still useful, yes they are accurate & reasonably priced. Its just that they don't perform this function which in hindsight for me would be very desirable. Why they continue to be sold in this configuration many years later would be a great thesis topic. Maybe the herd mentality (speaking as one from the herd): low cost & misinformed criteria. Until either/or dissipates, why change the drill bit :)
    I did notice offshore blocks that DO have clearance + tap hole combinations like the classic bolt-together blocks. For the most part they are sold in 'matched' sets of 2. Not sure why exactly. Makes me suspicious. Even on those you have to read the fine print in terms of the hole patterns & some do a lousy job elaborating & properly detailing. Either the middlemen distributers themselves don't understand what they are flogging, or its broken English trick to make you just throw the dice & buy them thinking 'logically they would work this way'.
    ASargent likes this.
  19. petertha
    163
    43
    City:
    Calgary
    State:
    Outside US / Canada
    -Return to Top-
  20. EmilioG
    294
    63
    City:
    HUNTINGTON
    State:
    New York
    -Return to Top-
    Yes, they cost more than import blocks, but these are so well made and bolt together perfectly.
    Suburban Tool Precision USA 1 2 3 blocks. They use 5/16-18 SCHS, 1" long. 12354_HDR.jpg 1233255.jpg 12300213.jpg
    Uglydog likes this.
  21. Reeltor
    Reeltor United States Active User Active Member
    239
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    I do love well made precision tooling. Everything Suburban Tool makes is really nice. I just can't justify the cost for the low tolerance stuff I (i pretend to) machine.
  22. EmilioG
    294
    63
    City:
    HUNTINGTON
    State:
    New York
    -Return to Top-
    I never pay top dollar for any of my tools. I always find a good deal somewhere. :)
    Ken from ontario and FOMOGO like this.
  23. scwhite
    scwhite United States Active Member Active Member
    210
    43
    City:
    Shreveport
    State:
    Louisiana
    -Return to Top-
    Brown & Sharp 1-2-3 blocks have the tapped hole in them I have two sets
    I love them
  24. Andyjb
    Andyjb United Kingdom Swarf Registered Member
    0
    1
    City:
    Norwich
    State:
    Outside US / Canada
    -Return to Top-
    I buy a lot of my tools second hand i have a guy near me deals in good quality used tools from companies that have shut down some is ex military very good value it some time pay's to shop around/
  25. gi_984
    gi_984 Active User Active Member
    51
    28
    City:
    madison
    State:
    Wisconsin
    -Return to Top-
    Second the Suburban Tools 1-2-3 blocks. Yes, they are expensive but will last a lifetime if cared for.
  26. Andyjb
    0
    1
    City:
    Norwich
    State:
    Outside US / Canada
    -Return to Top-
    The Suburban tool's one look very nice i have got stuff from the little machine shop in the past they are a nice firm to deal with also some time buy from US ebay i have a Atlas 10 lathe love the US made machine's and tool's but the post to the UK kills it. Just got a Rhodes shaper machines made in the USA and England back in the old day's were made to last now it all come from the over sea's.
    Love the forum some great stuff on here have spent a lot of time just reading the post i'm a new boy on here but hope to pick a few tips from you guy's my main love is steam engines big and small.
Share This Page
