I have decided to do a major round of upgrades after roughly 3 months of having it CNCd. The biggest issues I run into constantly are with the dovetails and spindle motor. The machine needs to be seriously babied and monitored because it loves to run just fine for an hour and a half, then stall one of the motors and rapid into the workpiece. The spindle motor also has a tendency to stall and shut off even with cuts I know it can handle. Now, even with the new gibs and lots of lube, I can't get decent travel along its whole range. In order for it to be tight enough to cut well in the middle, I risk stalling on the outside edges. If I loosen enough that it gets to both ends of travel, the middle will be very loose and chatter even with light cuts.
So I am getting rid of the dovetails and using linear rails instead. I scoured ebay to do it affordably and I ended up with:
2 22" Thomson Accuglide 25mm rails with 4 bearings for $150
2 19" IKO MLFG24mm rails with 4 bearings for $67
1 20" THK HSR20mm rail with 2 bearings for $80
The scrap aluminum I am using was about $60
This puts me at $357 for roughly triple the machining area and hopefully, much smoother motion and rigidity.
I plan to use the accuglides on the X axis, the IKO rails on the Z, and the THK rail will be cut in half and used for the Y.
Here is the model of the machine with the new rails. I need to change the Z axis to the IKO rails and bearings. Almost all of the new parts will be made using 3/4" aluminum. I found several large plates at a scrap yard that appear to be ground. I found a few high spots on the piece I am using for the table, but it cleaned up easily. The new table will be 8.5"x22" and the new travels will be about 15.5"x7.1"x8" (XYZ) and there will be roughly 5 extra inches in the Z that will extend past the top of the column which will be useful for very light cutting and drilling. The fusion 360 simulator says the weight of the head will cause the assembly to tip about .0003" and with a 100lb cutting force at the worst locations, the table will twist about .002" at the farthest and most will be under .001". With the head lower on the column and the table centered, which is closer to where 95% of my machining is, with the 100lb force, the table twisted .0007".
The second big upgrade is a new spindle motor. I have a 1.3HP treadmill motor that I will mount up. It isn't all that much bigger than the stock X2 motor, but it should have significantly more torque and I can gear up the spindle speed to 7200 RPM and still have more torque than the stock motor at its max speed of 4300 RPM. The treadmill cost me $25 which got me the motor, the controller, a big flywheel, a bunch of wires and bolts, and some steel.
Last, I got some encoders to add to the steppers to detect a stall and halt the program before anything breaks. The encoders can run at 2400 pulses per revolution and were $10 each. I read somewhere you can program linux cnc to use assist motors with the encoders to get faster rapids. That sounded like a fun possibility as well.
Here is the table having the ends machined. I squared it up against one of the edges and I may clean up the rest of the sides once it is finished. The top surface will also be flattened once the rails are finished and mounted on the machine.
If anyone has suggestions or questions, I am all ears.
