- Sep 22, 2019
- 1,049
Good Morning!
I am new here so please bear with me as I'm sure I will have a few more questions s I get my Jet JTM-2 set up.
Picked up this unit last spring on a whim when it popped up on C/L. It's a 1 owner circa 1985 machine from a small shop that used it balance pistons, or so I am told, and from the condition of the ways appears to have been lightly used. It came with all the original paper work, a few pieces of toling and a nice 6" (not Kurt) vice that included a rotary base for it.
We got it home and cleaned up and after an extensive remodel of my shop area have it positioned in a corner where it will live. Still waiting on the electrician to finish up the wiring and soon I hope to be able to use it. Will be a learning curve I am sure as I am not a machinist and have never played one on TV! I might add I am 6 years into retirement from OTR trucking pulling a step deck trailer all lower 48 hauling steel and machinery. Now I am into restoring IH Cub Cadet garden tractors having completed several in the last 5 years.
Question
Thinking of adding an X axis power drive and wondering what you fella's would advise. I see many new ones on e-bay in the $110 range and the others for 1/2 again as much to near double that amount. Are the higher end units that much better and which would you choose if in the market for one?
One other thing here, Is the gage setup I have pictured a viable way to tram this unit?
It is all I have at present. The tiny Mitutoyo 513-118 needle DI I do have is not (I think) working correctly as it jerks all over the place and will not return to the same spot consistantly.
Question
