Project is coming along nicely. Had to make a cutter for the keyway in the gear. Tried to use a 3/16 HSS lathe bit to cut it but there was too much flex in it and it wasn't long enough. Ended up with a T shaped cutter that zipped right through it. I wouldn't want to use it on steel, but it worked fine on brass.
Working on the trim ring now, since it will be visible I am striving for a good surface finish so I am not rushing it.
