I Have had Problems with 1 acetylene bottle and 2 argon/co2 bottles over the years that had either a faulty valve or damaged threads at the hose connections. I simply returned their damaged bottle to in this case my supplier (who owns it) and was given a replacement bottle free of charge. To be honest iv'e never heard of a rental bottle warranty. If you rent a bottle and there's a problem you exchange it, or so I thought. So what does a warranty actually cover on a rental bottle and why ?So your saying it was a mistake to buy an extended warranty on my rented bottle?!
Absolutely! Not only that, but caps and threads can get worn to the point that if you pick up the bottle using the cap, it can pop right off, then you wind up dropped a bottle with an exposed valve.I also learned that the threads that hold the safety cap on the cylinder are part of the neck ring, not the tank. That is why you don't lift from there. If the ring is not on correctly the tank will drop out of it.
