Would a 1018 cold rolled bar be OK for a draw bar?
My mill/drill came with a crappy draw bar that had a double nut design. I liked this idea so I made the replacement the same. With import arbors I've seen some varying in lengths. The double nut design allows you to compensate for this & speeds thing up for longer arbors.
I also had no spindle brake so the double nut design allows me to loosen the drawbar without having to lock the spindle. Would have to use 2 wrenches though but I normally I used a spline wrench to hold the spindle..
I used case hardened flange nuts 17mm on top, 19mm under. I pinned the top nut but the top nut is not used for loosening/tightening. I use a double end 17mm/19mm ratcheting box wrench for the drawbar. I have a spindle lock now so I don't use the spline wrench anymore but still like the adjustable drawbar.
This is what I bought. Stuck a 19mm socket on it. Use the ratchet part and the spindle brake together to tighten or loosen. Once loose, just let the ratchet run....works great. Harbor Freight
We always replaced the shaft of the drawbar with ETD-150 when it broke or stripped, threading and pinning into the original hex. Drawbars are a consumable, even more so with a power drive.
