#2 of shelf, i made the shelf removable so if i needed a whole table top to build something big on i could unbolt it and also to move it if need be "this thing is heavy boys".
slide out witch i have not welded up yet but you get the idea.the mounts for the slide out are receiver hitch material they are good for clamping other things in there , 2 in sq. tubing slides right in and tightens with welded in nuts and 1/2 in bolts .
