I built this little overarm router using a Stanley industrial router motor and a base salvaged from a scrap factory machine.
I made the cross and longitudinal dovetailed slides from 3/4" cold rolled steel bar stock, milled and ground. The cross slide is adjusted with a lead screw, but the vertical and longitudinal feeds use racks and pinion gears suited to the higher feed rates needed in wood cutting. There's also a pneumatic feed for the vertical slide, but I haven't used it much. I made the machine to do very accurate, small joinery cuts.
This tapered dovetail and miter joint is used in Ming chairs and tables. It's well illustrated in
Chinese Domestic Furniture by Gustav Ecke. It wasn't high on my list of things to try. Then I was told we could not possibly expect a Christmas visit from our granddaughter unless there was a new and very sturdy railing on the stairway to the guest room so she could be safely carried up and down. I thought of this as a way to attach the railing to the wood brackets that would hold it off the wall.
I cut a plywood shim tapered 1/16" per inch and used it to rout the jig for the tapered notches in the back of the railing.
After a couple of table saw and shaper cuts to make 2 shoulders on each bracket, I cut the dovetail on the long side of the miter. This cut is parallel to the edge. It's an up milling cut, so there's some tear out. I precut a bit of the end shoulder with a chisel.
Then I made a preliminary cut on the tapered side using the same shim to set the taper. This is a climb cut, so it is very clean at the end; but I was worried at first about kick back. The rack and pinion feed gave me really firm control of the feed rate, and this went very well.
The test fit has only partial engagement, so the end of the taper cut doesn't need to be cleaned up yet. Knowing the taper makes it easy to measure the gap to the shoulder and calculate the cross feed adjustment of the table for a tight fit.
Here's the finished bracket and railing. The tapered dovetail is glued and reinforced with a blind screw through the bracket into the railing. I like that the grain of the railing face is free of screw holes.
Here's the original staircase. The end of the new railing joins the old in the upper right corner. When we put on the addition with the guest room on the second floor, splitting the stairs so it went 2 ways saved the space a hallway would have taken up.
Hope you found this enjoyable and best holiday wishes to all.
