Finger or dovetail joints would certainly add a nice appearance, though without side/end grain like wood, the aluminum joints would not show as much contrast or appear as spectacular. Slightly different anodizing colors for sides vs front and back?:thinking:
-AND-
Those types of joints depend on glue to hold them together! Don't know what you'd substitute in the cast of aluminum - possibly drill down the joint and insert a long, thin pin?? Also recall, the rabbeted joint for the bottom of a wooden box is generally a bit loose, so as to accommodate uneven swelling with temperature/moisture changes. Aluminum isn't subject to much dimensional instability. You should probably make the joint relatively tight, or else the bottom would rattle.
The acrylic top would be a nice touch. Just be sure to clean up the aluminum parts, both inside and out!
