Shop I use to work at, We would thread a broken broom stick for our our floor sweepers.
Charl
Charl
while sawdust sledge is unsightly, it is better than ground steel and won't harm your ways in any ways.
I say go 4 it
Machining parts from wood works great, and as mentioned, hardwood works better than soft. I've made many prototype parts, jigs, etc from wood. The mess can be a pain to clean up, but it's not too bad. The only problem I've had with wood parts is that they don't heat treat worth a darn! :lmao:
If not thoroughly cleaned at the end of the day, every day the sledge will do damage. It will soak up the oil on the ways and cause unneeded wear. Then there is the oil contained naturally in the wood, it can cause corrosion. ------ "Billy G"while sawdust sledge is unsightly, it is better than ground steel and won't harm your ways in any ways.
I say go 4 it
Simple question - can one do satisfactory work on wood on a metal lathe?
