Of all the negative rake inserts I have tried, WNMG leaves me a bit confused. I never get great surface finish with it, not on either of my lathes, 2500 and 3000 rpm VS capable. I have spent a bit of time varying speeds and feeds and never come away completely satisfied with the results. They get into tighter areas than a CNMG, but don't seem to have much else going for them. So I do my hogging with either a Neg Rake HSS tool or CNMG and then finish up with highly honed HSS or Pos Rake insert. For low bucks and good finishes I like TPG in very small radius, with a slow feed, a good match for my toolmakers lathe. For doing ity bity stuff I use ccmt or ccgt or Micro 100 minature boring bars in carbide in a homemade holder, if you need to take a half thou cut in a very tight area, Micro 100 is the stuff.
I really like Wills thoughts on holders, find an insert that does what you want and then find the holder. I know for a fact that TPG does a lot for me for next to nothing cost wise. What they cant do for finish cuts I use smaller, more advanced inserts, but I doubt I will ever quit the TPG, its been around for 50 years or more, its not going away and has remained cheap for years.
