Today I mounted a 12 volt winch on a piece of 1/4 inch plate and bored a large hole on one end. The purpose of making
this is to be able to move heavy objects around in the shop. I added a few vertical pipes level with the floor when I poured the concrete
just for this purpose. If I have to wrangle a mill or lathe or some other heavy piece of machinery into the shop, it will be very
handy to have some holes to pull against.
For lighter jobs, a come along would work fine too. The white pipe affair on the right is to use with the come along or can be inserted
into the hole in the winch and to the floor hole. I went with the blue rope which has an unbelievable strength of over 8000 pounds
rather than using a steel cable. It wasn't particularly expensive and very nice to install on the winch. This winch will freewheel
so will be pretty handy when the need arises.
Yup, that's a photo of one of the holes in the concrete!
I can see a use for stretching something between two holes, probably for straightening something...
