While you're in there.... Take a look between the cam gears, there's three bolts that serve as galley plugs. Maybe 4 o'clock on one, eight o'clock on the other? It's been a while. Then one in the middle, slightly lower than the other two. I believe (I can't swear to it, but I'm pretty sure...) that the middle middle one feeds the oil pressure that turns cylinder two on and off. (Cylinders 1 and 2 get their own solenoids, and the remaining 4 are ganged in two groups of 2, which makes 1 and 2 NOT stand out in scan data when this happens- Those galley plugs have a very low torque spec, and have been known to back out. It's not enough that I'd call it a pattern failure, but it's enough that it's notable. Especially on engines that have seen an overheat situation, but they can back out on any engine. If there's any evidence that any have loosened or any history of being overheated, (and some techs will do this preemptively just when those bolts/plugs are visible) it's good medicine to remove them, clean them as well as practicable, and Lloctite them in place with a "more oil tolerant" flavor of of your choosing. It doesnt' need high strength, but it's also not a regular service point, so pick your poison. Or if nothing's wrong, let sleeping dogs lie. But it's at least worth peeking at.
