stick welding is a skill that takes a lot of time to master, but it is the best solution for many problems
if you get small diameter electrodes, you can weld sheet metal
if you have a large enough power supply, you can weld 1" plates
weld in the wind if you want to
poor fit up- no problem E6010/6011
rusted- no problem E6010/6011
new sheet metal E6013
structural/pipe fitting/general high strength welding E7018 (E8018,E9018,E12018)
High deposit E7014, E7024, E7032
E308L stainless
E309L stainless to mild steel
E312 mystery stainless
E4043 aluminum
stick is hard to beat other than the heat distortion
mig is convenient and easy to make superficially pleasing welds,
but you need shielding gas and you can't weld in the wind or even with a breeze, you'll need a 220v unit for anything over 3/16"
FCAW is great and fast
can burn through rust/scale,
but you'll have just as much spatter as stick welding, plus you'll need a 220v unit to weld anything above 3/16" correctly
Tig is great, but very slow and everything has to be very clean-
close fit up is necessary
the welder, the cooler, the torch(es), the leads, the multiple gasses -
all add up to be an expense that keeps most folks from wanting to play, not to mention the months of practice and that expense
if you get an inverter welder get at least 165 amps
good luck
