There is a lot of interesting discussion on this subject. Here's my two cents. I suspect that it comes down to simple economics. The tooling and production lines for all the mechanical parts needed to build a manual lathe are already in place and have been for decades, so not only do you have economy of scale, you are way down on the learning curve. As for comments that you could get a CNC lathe for just a little more, I don't think so. For an ELS equipped lathe, you have no need for a complex control system or precision ground ballscrews. Because it is still a manual lathe and will be used like one, you don't need production items like bar feeders, automatic tool changes and swarf conveyors. You would use the lathe just like a manual lathe, except the change gears or QCGB would be replaced with a motor (servo or stepper) and a simple controller. If you took a commercially available mid to high end lathe, redesigned it to have an ESL and were able to sell it, it would eventually be as cheap as a geared leadscrew manual lathe with a QCGB, I think. The problem would be you would have to take a loss on the initial ones (as they would be much more expensive than a geared lathe) and it would be quite a risk that they would ever catch on. If they didn't you would lose a mint. And at the lowest end of the hobby spectrum, the Chinese mini lathe, I don't see how you could replace a handful of plastic change gears with an ELS and not have a significant rise in cost.
